Is this correct? | SatelliteGuys.US
Is this correct?
Whoever told you that does not know what they are talking about. Anything with a Dish Network logo is covered under the warranty. I heard a rumor not long ago though that they were not going to cover certain things any longer but I cannot remember what that was or if it was even true.
I am being told that a bad Separator is not covered under the DHPP warranty program. Is this correct?
Who said THAT?!!!!!!!!!!!....Not true..It's covered...Jeez imagine the cancellations we'd get if those devices were not covered...You're safe....It's covered..
dish pro plus serperator is used to split the single coax into two coaxes for dual tuner receivers. A dish pro plus twin or a dish pro plus sat dish 1000.2 or dish pro 44 can be used with them .
Bad customer svc re: Install - is this normal?
Is this compelling enough content? YES Network HD in HD all the time
