is there such an animal | SatelliteGuys.US
techdood
SatelliteGuys Guru
I have multiple lnbfs on a single collector, both forward and toroidal reverse types, and always come across a single problem concerning direct tv's 110C head. Is there such an lnbf that performs BOTH regular full 32 transponder block down conversion and direct tv's shifted block in a single housing? You'd think since the 110C simply shifts banded freqs, what is Xponder 28,30,32 to Xponder 8,10,12 respectively, that those functions could be done using an in series filter or something. The problem im having is to install a separate 18" dish to accommodate either the 110C lnbf or a regular lnbf to collect the 110 orbital. Is there such an animal that would keep me from having to break my neck installing an extra collector? I'm assuming it would be like a lnbf with 3 coax ports, one 110C port and 2 for the whole band L&R. It could be in the form of a inline coax device, just for the 110C that would perform the small block conversion stated earlier.
-Keep having to mount an extra 18" collector
techdood (Paul)
how far away for Elevation 39
Best PQ for SD and HD between top 3
