Is there such a thing as a C/Ku-LNBF | SatelliteGuys.US
Virgil Gomes
49
Hello everyone,
Is there such a thing as an LNBF that can be used to reveive C and Ku band?
I read it in a post on "TalkAbout". I didn't think there was anything out there that could do that.
Thanks,
Virgil
Virgil,
I was advised against using a dual feed LNBF as they are notorious for poor reception. I would look instead at a Corotor, which is a feedhorn designed to take both C and KU band LNB's. A few companies manufacture them, including Chapperal and Eagle.
Virgil Gomes said:
Hello everyone,
Thanks,
Virgil
For a big dish it is best to get c/ku Lnb's and a dual band feedhorn. Chap,ADL feed's and maybe some Norsat Lnb's. well if you can get an lnbf free then go ahead :)
Hello everyone,
Thanks for the replys!!
It looks like there is a C/Ku LNBF, but you guys don't think it's a good idea.
Have you guys had personal bad experiences with them??
What do you think of just using a C-Band LNBF
(ASC421) http://www.dmsiusa.com/c-band_lnbf.htm
and strapping on an FSS linear Ku LNB. Can I do that?
Does anyone have experience with the ASC421?
Thank you,
Virgil
What dish are you using? Like the others said before if you are using a BUD setup, then by all means get a CorotorII with a 17deg (or lower) C-band LNB and a wideband .6db Ku-band LNB. Buy high stability if you are doing some serious hobbist stuff. Don't limit yourself to just one type.
http://www.skyvision.com/store/mi3503007.html
http://www.skyvision.com/store/mi3500010.html
http://www.skyvision.com/store/mi3500024.html
http://www.daveswebshop.com/ku_5.shtml
http://www.daveswebshop.com/15_deg.shtml
http://www.daveswebshop.com/otherlnb.shtml
http://skyvision.com/store/lnbs.html
Man I need my CND to USD conversion chart because that Skypack Level 3 is the deal but WOW sticker shock; then I saw it was in Canadian dollars. WHEW!
If you are in the USA I would "somewhat" advise against buying over the boarder until you do the conversion (USD is stronger). Also might have some delays via customs and weather issues.
I use this to convert http://www.bank-banque-canada.ca/en/exchform.htm
Well after the conversion from today's exchange rate you will be spending about $15 more in Canada before any shipping and handling charges.
If I where in the US I would call Dave's Webshop at 479-997-2230 to get a package quote. I have order many items from these guys and it is top notch. Thus avoiding any customs issues and delays and save a few bucks in the process. Skyvision is $15 cheaper and they are usually high dollar.
If you are in Canada then that changes everything.
Call Letters For Abc Feed
KTWO-tv ABC
