Is the Silver Sensor still the best indoor antennae for HDTV? | SatelliteGuys.US
Holysmoke
185
11
I really did do a search and it seems it is, but I cannot find it anywhere, even ebay.
Is there another antennae that works better now?
an outdoor antennae is not an option
Zenith Silver Sensor was a UHF only indoor antenna. Over the years many knockoffs came out the most succesful added a dipole antenna for VHF signals. Go to www.antennaweb.com or TV Fool to find out what frequencies are used for broadcasting in your area also to get a recommendation what you need for antennas.
Grossly overpriced for the cheap piece of plastic that it was. And yes, it was UHF only. Here is a much better knock-off with rabbit ears and a very solid/heavy base: Terk/Audiovox HDTVa I bought mine for about half price from Amazon Warehouse. I have the Silver Sensor too, and it's performance is about the same as the UHF portion of the Terk without the Terk amp even turned on.
Cool TV on Minneapolis 23-2
RV antenna installation help - but for my home!
