X Xstation SatelliteGuys Family Original poster Sep 24, 2007 62 2 Sep 19, 2009 #1 just a quick question... is it compatible? having it installed as I type - installer is saying that it might not work.
harshness SatelliteGuys Master May 5, 2007 20,084 5,076 Salem, OR Sep 19, 2009 #2 It was designed to be FTM capable so as long as it works as designed...
ChrisK114 SatelliteGuys Pro Pub Member / Supporter Jul 17, 2005 1,051 4 Mount Pleasant,SC Sep 19, 2009 #3 I have one in my SWM setup, so yes it will work.
Liquidforce88 SatelliteGuys Pro Feb 3, 2005 3,738 39 The Land Of OZ Sep 19, 2009 #4 If it has old Software it may need to do a download first. Otherwise it should work fine.
F FreshTech New Member Aug 11, 2009 3 0 Mesquite, Texas Sep 21, 2009 #5 you have to update it first, but when you choose a dish type it will say SWM. You have to put it on Slim 3 or Slim 5. and it works
