Right now, I have 2 EHD's. When I go into my DVR, I can see everything stored on the Hopper 3, but have to change the source to see what is stored on the EHD's. Is there a way to see all my recordings at once, regardless of where they are stored?
I agree. The external drive(s) need to be more transparent. It shouldn't matter where a program is stored in order to show up in the program list. This should be an option along the lines of setting up what drive(s) (internal and any selection of external) appear in the normal program list.Thanks for answering. Too bad, though. That would be handy.
Naming drives so they don't jump around in order would be necessary for this to work also.
Making programs on external drives accessible from DishAnywhere, too!
Thanks! I did not know that search would look at my EHDs.If you know what you are looking for, by title, you can do a search: Home twice/Menu, Search. From there you enter the title and you will get to see that title on your H3 drive as well as your EHDs. For example, I have The Godfather Epic on my number 1 EHD. I go to search, type in The Godfather Epic (or at least most of it) and I see it pop up on the right side of the screen. I go over to it and select it and I am brought to my resume/start from the beginning/delete screen. I press start from the beginning and I begin, from the beginning of the movie, to watch directly off the EHD. Another fun thing, if you have the 50 remote, you can say it into the remote and it will bring you right there!
Limited time offer
