is my computer strong enough | SatelliteGuys.US
rsa72
4
I hope I am in the right forum do not want to get in trouble, but I have a compaq intel celeron processor 356 with a navida 7200 grafic card. I was wondering if it can handle a dvb tuner card and do 4:2:0 and 4:2:2 hd. I love the feeds. I also have an 85cm dish with a sg2100 motor. Thanks in advance.
I'm able to view regular 4:2:0 and 4:2:2 feeds on a celeron 500 with 128mb of ram. It doesn't have enough horsepower to do HD though. For HD, you want something in the 1.3 gb range as a minimum.
Hi, you did not say what your CPU speed is but a quick google on "celeron processor 356" says it is a 3.33 GHz. That may well be enough to run HD.
How much memory are you running? What do you have for audio?
While I have not tried to run HD on my setup it runs SD so easily that I think it might handle HD. I can watch TV and surf the web at the same time with no problems The CPU usage averages around 15%
So you have something to compare with my setup:
P6NGM-FD MB with 1.6 GHz dual core, 1 GH ram, Nvidia 7100, XP Pro, ProgDVB, SS2 PCI DVB card.
BTW - where are you finding HD on Ku? I thought all the FTA HD was on C-band? What feeds am I missing?
Thanks, DC
Diamond channel list
Fta sats
