Ok here is my question (I read about this somewhere but cant remember where), is it possible to run 8 LNBF's to one receiver using 2 DiSEqC switches and a 22kHz switch?
I am curious on the set up of 12 lnbf's (not that I think I would ever need that many on one receiver).
ok I have another question...the first set up of 8 with the 2 DiSEqC switches and the 22khz switches would NOT work with universal lnbf..Correct? (it figures that would be the case...I have a but load of universals...LOL.
However, if you have a 4 port diseq switch you could get 8.
Remember you don't absolutely have to use multiswitches. You can also do what is on the second graph.
You could also go to 32 lnbs using a 0/12v switch.
Labgate
Visio-16 LNBs with multiswitches and 22 khz switches.pdf
200.9 KB
Visio-16 LNB ON 1 RECEIVER WITH 8 22 KZH SWITCH.pdf
