Is Alignment OK, or any Advice? | SatelliteGuys.US
Longjack
67
2
Have a question about aligning a AU9/SL3 using a H25 receiver instead of a meter.
Went thru routine and dithering and am getting below numbers.
Satellite Transponder Strength
101 1 96%
99(c) 1 88%
99(s) 1 0 - Not acquired
103(s) 0 0 - Not acquired
103(ca) 9 82%
103(cb) 1 95%
In any event, even with low strength on lot of the satellites and not being able to acquire 2 of them I am getting all my channels, so am a little confused.
As it took me a fair amount of time doing the aligning without a meter and it is a delicate routine, I am thinking I should leave well enough alone….anyone have any ideas…or any fine tuning the dithering control suggestions if I am to make adjustments?
Many thanks.
The "S" designated satellites have spotbeams, so you will get low numbers on many of the transponders. Can you post all of the signal strengths for all of the transponders on all of the satellites?
Reactions: Olalekan
Is Directv getting the new Sportsnet Lakers channel?
Max number of receivers off of one dish?
