If this big move to MPEG4 happens is my 522 mpeg4 ready or do I need to upgrade. I assume since its a newer model that it is ready to go.
Nope. There are only six Dish MPEG-4 receivers: 411, ViP211, ViP222, ViP622, ViP722, ViP612.If this big move to MPEG4 happens is my 522 mpeg4 ready or do I need to upgrade. I assume since its a newer model that it is ready to go.
The 522 is probably close to 5 years old, isn't it ? I had one years ago (been back with Dish 2 years, had TWC for almost two years before that).I assume since its a newer model that it is ready to go.
The upgrade charges vary based on your customer history. Log into your account on DISH Network -- Home, and drill down through the equipment menu to "Dishn'-it-up". I don't think you can swap an SD DVR for an HD DVR at no charge, but I could be wrong.Thanks, My 722 is ready to roll, I will just need the 522 swapped if/when it happens. I may get an hdtv for the bedroom soon so that may not be a problem. If it happens before then I assume dish will swap it for a Mpeg4 type at no charge. I may wait it out if that is the case.
Limited time offer
