Invacom LNBF for prime focus dish? | SatelliteGuys.US
MikeC55
10
I currently have a Pansat 3 foot portable satellte dish (prime focus) and an old .6db Pansat LNBF. I am thinking about purchasing the Invacom SNH-031 (LNBF .3db) and installing it on my dish.
It this possible? Can the Invacom SNH-031 be installed on a "prime focus" type dish?
I read Cascade's review but not not see if this LNBF could be used on a "prime focus" dish.
Thanks,
Mike
You'd have to first make sure you can mount a C-120 flanged LNB on the Pansat feedhorn. I'm not sure what they use as an interface.
I pulled a 36" prime focus dish out of the trash a couple of months ago. I haven't set it up since I'm sure my 30" offset Winegard outperforms it. The LNB blockage on a prime focus of that size makes a considerable difference.
The dish I rescued has a screw-together assembly which locks the feedhorn to the feed support arms. The LNB is secured to that assembly with four Phillips screws. It is (I believe) a Norsat .7 single polarity model.
Anyway, this LNB uses a WR-75 waveguide interface, which wouldn't work with C-120.
Will be ordering my motorized FTA System on Monday....
Grounding Run
