Intelsat 9 sharing 24" dish with Intelsat 707 | SatelliteGuys.US
magnigyro
326
2
Looking front the dish, the lnb for Intelsat 707 set at center and the other lnb to the right.
I just put the lnb for Intelsat9 a little bit lower and little bit front the lnb for Intelsat707...
The signal is very strong rises to 80-85% for Intelsat9..!
Now...blind scan charge to my Pansat 2500a a lot of $channel from Mexico I think...:D
However, I see some channels without the $..! Today after work I will to explore this bird.
One of they says some like "Game... waiting to download...." Whats that?
Someone has had experience with this bird?
You are receiving the Sky Mexico channels. All are encrypted except three promotional channels and the interactive download screen which you are seeing.
Thank you for your answer...
Today evening I´ll see if I got that FTA channel from Cuba...:confused:
you need a Universal LNB to get Cubavision on PAS9
:(Mmmmm...no....none of the two FTA in the list! are in my scan, despite the fact that quality in the $ channels is 85-92%
Thanks Ice....I will test another lnb....tomorrow.:sleeo
Cubavision is at 11612 so you need a Universal LNB. Standards only go down to 11700 Mhz
Well, Mr. Iceberg, now I have Cubavision.
I put a universal lnb, blind scan catch only Aastha chanel but....with pol. V!! (lyngsat and the list! mark: H).
No cubavision, zero quality in 11613 H 3671...:confused:... then...:eureka
I edit tp changing H for V..... bingo! quality 40%...after little adjustments Q go up 72%, enough for me.:)
Mmm...strange world I see....:eek:
Thanks...
sounds like the polarity is off by 90 degrees. Both of those are on H side
:rolleyes:I dont understand nothing of that...only know that with "H" I got any quality.
while work polarity "V" bring me...the oportunity to know a new world...and its beautiful native women.;)
You have the LNB skewed the wrong way. When a LNB is skewed the wrong way you'll get the V polarity stuff on H and vise versa.
Twist the LNB 90 degrees and then the H stuff should be on H :)
:)Ah...Ok, Sr. Thats was the cause?:o. Thanks...
yep. That usually is the reason why people get a set of channel that should be on one polarity as the opposite.
Done that a couple times with C-Band :)
What is going on with Equity Media.
Cannot get one channel
