installing motorized system this weekend | SatelliteGuys.US
janzy
SatelliteGuys Guru
126
There's been a break in the weather this week in the northeast, so I got a chance to start my motorized install with a trip up to the flat roof to bring up the non penetrating roof mount.
I should have time to finish everything up this weekend.
I have a Fortec 90cm dish with a sg2100 motor and an Invacomm quad lnb.
I have a Skywalker-1 in my den and a Pansat 9200HD in the living/theater room.
Which one of these receivers would I be better off using to move the dish?
And, depending on which one, should I use diseqc or usals?
The Skywalker-1 is a computer card right? If so use the STB (Set Top Box), the Pansat, also try to use USALS since it will be easier to find other satellites once aligned properly.
Sadoun Will Keep Me Warm!
Trouble with USALS accuracy
