Installing a 322 receiver | SatelliteGuys.US
204036212
2
I currently have a dish network 301 installed. I want to purchase and install a 322. Will the 322 switch out with the 301. The 301 has one coaxil wire coming from the dish, will that work on the 322. Are there any other things to consider.
what type of LNB do you have go to MENU 6-1-3 it will do self test on line (h) it will tell you LNB and switch. let us know so that way we can help you
The 322 needs two line from the DP-Twin, run a second line. If you plan on keeping the 301 you'll need a DP34 switch or swap the DP-Twin with a DPP Twin and run one cable to the 322 with a separator and one to the 301.
Getting your 622 Tracking Number
921 to parents?
