Does anyone know of an installer in the NE Atlanta area that could hook me up to my AT-9 with a third drop? It needs to go from the attic through a trough (fairly packed) to the basement. DTV installer said that glow rods won't handle it.
Spade said:Good luck buddy. Wall fishing is impossible (besides the electrician) for 99.9% of all installers for anything more than 2 story high.
hall said:Do you have a spare wire of any sort in that trough that you can use to pull the cable ??
dervari said:There is a cable chase from the attic to the basement. I just don't have the equipment (or desire) to do it myself.![]()
Reason I suggested that was there was an old alarm system in my house and a number of wires ran from the basement (from the alarm panel) up to the attic (3rd floor) via the vent stack "opening". One of the wires was labeled "spare" in fact so I used it to pull a CAT5 cable years ago (when wireless routers cost $300, not $50).The Tate said:99% of the time a cable that was put in during the construction phase will be stapled to the framing to insure it will not get between the drywall and the frame.
hall said:Reason I suggested that was there was an old alarm system in my house and a number of wires ran from the basement (from the alarm panel) up to the attic (3rd floor) via the vent stack "opening". One of the wires was labeled "spare" in fact so I used it to pull a CAT5 cable years ago (when wireless routers cost $300, not $50).
Mike500 said:This is the kind of wall fishing that I do everyday. Some wall fishes are tougher than others. With no prepared chase, I usually use interior walls. Even those with horizontal fire stops can be handled. Exterior walls full of insulation can also be done.
The toughest wall fishes involve homes with foamed in insulation. I've done those, too.
stickboy75 said:I don't work in to many one story ranch houses, usually two story colonials but here goes...
So your telling me you send a drill bit down an 8 ft. wall from an attic with a 8 pitch into the 2nd floor bottom plate then continue thru the 1st. floor top plate, (all doing this blind I might add, for the people that don't know how a stick built house is built) and full of insulation... Hmmm must have missed that class in Electric 101...
Now even attempting this from the basement the odds of success without damage to any wall finish is just to risky... at least in the houses I work in...
stickboy75 said:So your telling me you send a drill bit down an 8 ft. wall from an attic with a 8 pitch into the 2nd floor bottom plate then continue thru the 1st. floor top plate, (all doing this blind I might add, for the people that don't know how a stick built house is built) and full of insulation... Hmmm must have missed that class in Electric 101...
Mike500 said:For each floor, the technique involves cutting standard 2x4 standard "old work" electrical box holes within two inches of the stud in the wall cavity and at the same level as the other wall outlets. This allows using the long flex bit, which has a self feeding auger screw to pull itself in to drill through the floor plate, the subfloor and the top plate into the lower wall cavity. Using extension rods, the cable is push down from the attic to the second floor box access hole. Then the rods are used to push the cables to the first floor box access hole. And, then to the basement. When finished, I'd just pop an orange "old work" low voltage box frame and cover the access with a blank box cover that matches the others in the room.
The advantage to the access plates is that new wiring can be pulled in the future with ease, if the need arises.
Limited time offer
