Installer recommendation for Houston | SatelliteGuys.US
Bear
SatelliteGuys Guru
124
I am planning on doing the bulk of my own install, but the place that makes sense to me to put the dish doesn't seem to be covered under a "standard" install (on the chimney). Does anyone have any recommendations for an installer in the greater Houston area that I can use for installing and sighting the dish? The wiring will take about ten minutes once the dish is up (I've already got the wiring in the walls done...).
Thanks!
We have a member here with the name of SKsatellite I think he is from around there and does good work, drop him a PM and see if he is close by or knows someone who is!
It seems that SKsatellite is in Dallas, not Houston. Are there any other leads that folks have? Thanks!
Peter - Thanks! I did try them, but there are apparently no DBSInstall members within 50 miles of Houston. I'll keep looking.
Thanks!
TiVo Series 1, no land line, can I get DirecTivo?
Help ... Multiswitch causing problem with local channels
