Yep. Used an older SSB with the 21 volt output. Hooked it up to the SWM-3 lnb and BANG...upper 90's and 100's across the board..
No problems. None of that dithering baloney. All sigs good on 99 and 103....
Hmm. I was then misinformed. I looked at several posts on various sites that the 21V SSB would not power the SWM LNB's...Some people did say it could be done but with significant battery drain..
Oh well.
I simply used the 101 slot for the tuning of the antenna.
Oh well.
You can run a SWM LNB off a receiver (not always and very unstable) but it'll work, I've seen some home made power inserter and I just sit and stare at them
