Installation Question--grounding | SatelliteGuys.US
holman3rd
42
My D* system in self-installed and I currently have 2 coax lines running from the dish through a dual grounding block, which is then connected via copper wire to my house's ground. I also have the dish itself connected to the grounding block via copper wire.
I'd like to add a 3rd coax line and was wondering if I could just buy a 2nd dual grounding block and mount it next to the existing block and connect the two via a short piece of copper wire.
Or, are there triple or quad coax grounding blocks available. I checked RadioShack's website, but they only had dual blocks.
Thanks.
I need to order a couple of these myself:
http://www.dishstore.net/product_info.php?cPath=23_34&products_id=89
DISH/Viacom Talks Continue, DirecTV Inks Deal
A larger dish...?
