Installation help 211 receiver | SatelliteGuys.US
mrlasvegas
33
Los Angeles, City of
Doing a self installation and it's not going as planned (zip 90064)
Here is what I have:
3 Satellites going into a multi-dish switch dpp44 (on the left side, room for 4 inputs).
A line going out from the bottom (labeled to power inverter) to a power inverter dp44 then into a dpp seperator which splits it into 2 lines which feed the 622 all is fine and working properly.
there are 3 other outputs on the bottom labeled to receiver satellite in
How do I get the 211 hooked up?
if I take the line that was hooked up to the 622, and run a check switch I only get the 110 satellite
if I run a line from 1 of the 3 outputs to the 211 and run a check switch I don't get any satellites
I haven't activated the receiver yet, don't I do that after all the satellites are recignized?
thanks
If the 622 is working properly and you remove the cable going into the separator and plug that to the 211 and it doesn't work, sounds like you got a defective 211.
Some receivers require a software download before they recognize certain newer switch configurations, but I think the DPP44 predated the ViP211 by at least a couple of years.
"Dish Quality" team
Left DISH in 07, Looking to Come Back
