Install with multiple receivers. | SatelliteGuys.US
warper
46
I just talked to voom and wanted to change my order. I have 2 receivers coming on the 11th to be installed. I called them to ask about upping it to 3. I told them I wanted to have 2 right next to each other and be able to set one up to record 1 channel to my hdd/dvr over component 480i. I wanted the the other to feed direct into the big screen. basically I figured it would than be like having a voom dvr but not as good of quality. They said it would not work. They say if I change the channel on 1 remote it will change on both stb's. I was surprised they did not have where you could set different signal for each remote. I s what they say true?
I never thought about it, but it doesnt have a switch like my dvd or cd changers. So it probably would change both, unless they have 2 different models.
Of course you could always block the IR on the one box, so the remote couldnt change it.
Yeah it does do that - it sucks.
You could always tape over the IR EYE and try to get an RF remote to work for the #2 reciever. I think some of the FTA reciever RF remotes are supposed to work.
Shawn
Another Newbie Quesiton on VOOM remote programming for my TV
VOOM OTA tuner vs. DISH 811 OTA tuner
