Install Questions Regarding Using the Proper Switch | SatelliteGuys.US
RickCathey
43
Doing a self install on an E* system and have a question.
I am currently trying out the VOOM service and their dish is pointed at the 61.5 satellite. I bought an 811 and installed it to the second connection on the LNB of the VOOM dish and got it activated with a sub for the CBS-HD feed. That works like a champ.
I also have an old D* dish in place that houses a single LNB from a previous install that I am not using anymore. The cable from it is still in place. I want to re-position it to the 110 location so I can receive more programming from E*. Both the VOOM LNB and the old D* LNB's are just the plain jane type - nothing fancy like they using now.
I will only be using the single 811 unit with no plans for needing another receiver so I need to combine the two lines down into the satellite connection on the back of the 811.
What do I need to accomplish this?
Something like this?
http://www.radioshack.com/product.a..._name=CTLG_003_008_003_000&product_id=16-2577
If so, this seems to be a little overkill for me as I don't need the OTA connection or hookups for 4 receivers. Is there anything out there with just the 3 connections I need? 2 lines in > 1 line out
Thanks...
Rick
No, that switch will not work in your setup. You need a DISH Network Legacy SW21 switch. You can purchase from Claude and Scott here: http://www.dishstore.net/advanced_search_result.php?keywords=SW21&x=6&y=6
You will run the 61.5 feed into one input, and the 110 feed into the other. You will need to go into the menu of the 811, and run a "check switch" test, the receiver will see the switch, and you are ready to go.
Thanks Al..
Much appreciated..
Rick
Free Preview of some AT150 channels
email addy to report poor local quality
