install help? Elevation/declination | SatelliteGuys.US
airgator96
247
Kansas City BBQ Heaven
install help! Can't change btw sats
Ok I have the digipower sg 2100, and it says this on
http://www.sadoun.com/Sat/Installation/HH-mount-installation.htm#trueSout
= 30 minus declination angle
So what is my elevation angle?
i'm in 64137. I'm not sure if i'm suppose to look up a sat and enter what it is for that sat or if its just one spot, and the motor will move to the elevation. If its just one setting and the motor moves.. i'm not figuring out the one setting?
Motor Elevation = 51º
Dish on Motor Elevation = 24º
(The below elevations are WITHOUT a motor)
Your True south satellite is G3C @ 95ºw
Code:
                     Kansas City, MO 64137
         Latitude 38° 55.794'N Longitude 94° 32.430'W
                       Sat Name Sat Lng Az(t) Az(m)   El  Skew
                       Amos 1/2    4.0W 269.7 266.5 -9.0 -51.1
                Atlantic Bird 3    5.0W  90.3  87.1 -8.3 -51.1
                Nilesat 101/102    7.0W  91.5  88.4 -6.7 -51.0
     Telecom 2D/Atlantic Bird 2    8.0W  92.2  89.0 -6.0 -51.0
                     Express A3   11.0W  94.1  90.9 -3.7 -50.9
                 (C) Express A4   14.0W  96.0  92.8 -1.4 -50.7
                     Telstar 12   15.0W  96.6  93.5 -0.6 -50.6
                   Intelsat 901   18.0W  98.6  95.4  1.7 -50.3
                          NSS 7   22.0W 101.2  98.0  4.8 -49.7
                   Intelsat 905   24.5W 102.9  99.7  6.8 -49.3
                   Intelsat 907   27.5W 104.9 101.7  9.1 -48.7
                  Hispasat 1C/D   30.0W 106.7 103.5 11.0 -48.2
                   Intelsat 801   31.5W 107.7 104.6 12.1 -47.8
                   Intelsat 903   34.5W 109.9 106.7 14.4 -47.0
                     (C) AMC 12   37.5W 112.2 109.0 16.7 -46.1
                        NSS 806   40.5W 114.5 111.3 19.0 -45.1
                      Pas 3R/6B   43.0W 116.5 113.4 20.8 -44.1
                         Pas 1R   45.0W 118.2 115.0 22.3 -43.3
               (C) Intelsat 705   50.0W 122.6 119.4 25.8 -41.0
                   Intelsat 707   53.0W 125.3 122.2 27.9 -39.4
               (C) Intelsat 805   55.5W 127.8 124.6 29.6 -37.9
                          Pas 9   58.0W 130.3 127.1 31.3 -36.4
                       Amazonas   61.0W 133.5 130.3 33.1 -34.4
                     EchoStar 3   61.5W 134.0 130.8 33.5 -34.0
                      Rainbow 1   61.5W 134.0 130.8 33.5 -34.0
               Estrela do Sul 1   63.0W 135.7 132.5 34.4 -32.9
               (C) Brasilsat B2   65.0W 138.0 134.8 35.5 -31.4
               (C) Brasilsat B1   70.0W 144.0 140.8 38.2 -27.2
                       Nahuel 1   72.0W 146.6 143.4 39.2 -25.4
                      DirecTV 1   72.5W 147.2 144.0 39.4 -24.9
                          AMC 6   72.0W 146.6 143.4 39.2 -25.4
                          SBS 6   74.0W 149.2 146.0 40.1 -23.5
                 Echostar/G4R 4   77.0W 153.3 150.1 41.4 -20.5
                          AMC 5   79.0W 156.1 153.0 42.1 -18.3
                      Nimiq 2/3   82.0W 160.5 157.3 43.1 -15.0
                          AMC-9   83.0W 162.0 158.8 43.3 -13.9
                (C)Brasilsat B3   84.0W 163.5 160.3 43.6 -12.8
                          AMC 2   85.0W 165.0 161.9 43.8 -11.6
                          AMC 3   87.0W 168.1 164.9 44.2  -9.2
                           IA-8   89.0W 171.2 168.1 44.6  -6.8
                      Galaxy 11   91.0W 174.4 171.2 44.8  -4.4
                     Nimiq 1/4i   91.0W 174.4 171.2 44.8  -4.4
                (C)Brasilsat B4   92.0W 176.0 172.8 44.8  -3.1
                           IA-6   93.0W 177.5 174.4 44.9  -1.9
                      Galaxy 3C   95.0W 180.7 177.6 44.9   0.6
                           IA-5   97.0W 183.9 180.7 44.8   3.0
                      Galaxy 16   99.0W 187.1 183.9 44.7   5.5
                     Spaceway 2   99.2W 187.4 184.2 44.7   5.7
                DirecTV 1R/4S/8  101.0W 190.2 187.0 44.4   7.9
                          AMC 4  101.0W 190.2 187.0 44.4   7.9
                     Spaceway 1  103.0W 193.3 190.2 44.1  10.3
                          AMC 1  103.0W 193.3 190.2 44.1  10.3
                         AMC 15  105.0W 196.4 193.2 43.6  12.7
                       Anik F1R  107.3W 199.8 196.7 43.0  15.3
                     (C) AnikF1  107.3W 199.8 196.7 43.0  15.3
                      DirecTV 5  109.5W 203.0 199.9 42.3  17.7
                  EchoStar 8/10  110.0W 203.8 200.6 42.1  18.3
                        Anik F2  111.1W 205.3 202.2 41.7  19.4
                       SatMex 6  113.0W 208.0 204.8 41.0  21.4
                  Solidaridad 2  114.9W 210.6 207.4 40.2  23.3
                       SatMex 5  116.8W 213.1 209.9 39.3  25.1
                         AMC-16  119.0W 215.9 212.7 38.3  27.1
                     DirecTV 7s  119.0W 215.9 212.7 38.3  27.1
                     EchoStar 7  119.0W 215.9 212.7 38.3  27.1
          EchoStar 9/Telstar 13  121.0W 218.4 215.2 37.2  28.9
                     Galaxy 10R  123.0W 220.8 217.6 36.1  30.5
                  (C) Galaxy 14  125.0W 223.1 219.9 35.0  32.1
                   Galaxy 13/H1  127.0W 225.3 222.2 33.8  33.6
 Intelsat Americas 7/Echostar 5  129.0W 227.5 224.4 32.6  35.0
                     (C) AMC 11  131.0W 229.6 226.5 31.3  36.3
                  (C) Galaxy 15  133.0W 231.7 228.5 30.0  37.6
                     (C) AMC 10  135.0W 233.6 230.5 28.7  38.8
                      (C) AMC 7  137.0W 235.5 232.4 27.3  39.9
                      (C) AMC 8  139.0W 237.4 234.2 25.9  40.9
                   EchoStar 1/2  148.0W 245.0 241.9 19.4  44.8
       Satellite Finder is (c) Copyright 2004, P. Lutus
IA-5 is at 97w so you are just 2º away from G3C (From behind dish you need to go to the left 2º)
Use this transponder, its VERY strong...........
Freq. 11780
Pol. H
SR. 20760
i played with it a couple of weeks before i got a motor and that kinda got me a good feel for direction of the south sat. and movements for the next satellites 2 degrees isn't alot and using a live transponder like Pete has listed really helps hone in on a good signal.... these guys here are great with instructions and pointing tips. Main thing is not to give up and not to get frustrated. just come back and ask more questions if you don't get it. I don't know who said it but its true "The only dumb question is the one not asked."
good luck
i've did a full scan and got about 7 channels some of them were 70+ strength. I don't know what that means. I'm going to run a full scan on all the channels and see what I come up with... Looks like this will be a few day asignment. If I can avoid a install that would be great.
70% signal quality is GREAT, you should be getting the CCTV channel.
I get them at around 77% signal quality here in MN.
(I use a Traxis DBS 3500 receiver, 36" dish and an Invacom QPH-031 LNBF.)
Seems weird... every Sat I move to, and do a full scan with... I get the same channels on every sat?
Do you think the motor is moving the sat?
The channels I'm getting are in the 70-80% range
On G10 Kuil (FOX) is the only channel i'm getting, besides like all the others the same channels over and over.
I'm lost!
Kuil fox is on AMC-4 @ 101ºw
http://www.lyngsat.com/amc4.html
Somethings not right, if you are using USALS make sure you have your latitude (N) and longitude (W) set correctly in the antenna set up screen.
If you are using DiSEqC 1.2 enter a LIVE transponder from the satellite you are looking for and watch for signal QUALITY as you move the dish/motor.
What type of receiver do you have? Are you using USALS or Diseqc 1.2 to move the motor? Somewhere in your setup on your stb you should have a section to input the values of where you are at. Then you should have a dish setting or something similiar. Also check to see that lnb power = on and that the LOF = 10.750 hope this helps.
Ok I have G3 as my south point.
When I try to set the position of another sat the motor moves to the right every time, and goes right back to the south point? Any thoughts on whats not right?
Mke sure you have your Latitude (N) and Longitude (W) set correctly in the antenna set up screen.
where do I do that? the only place I see anything like that is under "set"
I've tried usals and DiSEqC
Under usals nothing moves. Under diseqc it just moves to the right then back.
I have found every sat, and have good quality on all of them. I put in my long/lat, and when I set the channels it seems everything is fine. then when I go to change sat's the only one it will go to is my true south.
are you setting the motor up at every satellite. my first motor mistake was i set only one satellite up, i did put the long & lat in but i didn't goto each satellite setting in the receiver and set it to either USALS or 1.2 i went back and did this for each satellite one at a time and they all worked.
for my receiver under the "motorized settings" it says
diseqc motor : none USALS 1.2
one must be selected if none is selected the motor wont move to this satellite
well that was the mistake i made, good thing i learned from it :)
good luck
either my receiver is broken or my motor is... I have gone through this over and over, and it will not keep the sat saved, once I try to swap sats and it forgets the last on I went to.
any experts on fortec classics with mortorized dishes? With last advice before I send some things back?
Traxis DBS 3500
I got an all-in-wonder card sending monitor to tv
