Ineed help plz!!! | SatelliteGuys.US
Ineed help plz!!!
Dreambox2010
California
I am trying to setup my new equipment for FTA. I am confused though about the fact that I have a signal strength of about 70% and a fluctuating quality between 30-90%. But there is only one things named BER have no signal and when I scan for channels I do not get anyhting. By the way, I still get the same strength and quality when I have the LNB inside the house not pointing to anything!!!
So, is this normal? How do I know when the strength and quality are really from a satellite and that I am going get programs.
Here is a list of the equipment I have: Dream-box dm500 s
Antenna i have no idea i just use the Direct TV one its small with two head,
can you help with any idea also i live in Sacramento ZIP 95827
A DirecTV LNBF will not receive any FTA. You need a 30" or larger dish with a linear Ku-Band LNBF for these satellites.
BER means Bit Error Rate. High BER is bad, high Quality is good.
Direct TV and Dish Network use a circular LNBF. Whereas, most of the dishes for FTA reception in America use a linear LNBF. You could use a circular LNBF for sat reception for the Atlantic region of the sky but you would need a larger dish and since you're on the west coast, the Atlantic satellites may be below your horizon in order to receive them. Good luck
T90 Circular feeds
GeoStat 200 reciever review and C Band setup
