inclinometer | SatelliteGuys.US
inclinometer
jagee
SatelliteGuys Guru
149
How do i set my angle on my motor with this instrument.this is the only setting there is. on the motor H180.my lat is 33.5 long 82.2
If you're at 33.5 degree's. Then your HH180 motor should be set at 33.5 degree's. Then there should be about a 4-5 degree declination for the dish, which would put it around 38-39 degree's. If you can't read your instrument, I'm afraid I can't tell you how? Good Luck!
Al
Iwent to google and read alot on how to use it.Thanks,I do have another question on the same mater kinda. you say i should set my motor to 33.5.I thought that was a dish setting only.thanks ill try it
C Band
Sbs 6
