improving picture quality | SatelliteGuys.US
RedAce
47
Just wondering if anyone can give my a few tips on improving my Picture quality for my iptv OverseaTV.
for the most part it is really fairly good bit i like to watch soccer and hockey games and then the quality goes down because they are such fast moving sports. any idea's on what i can try?? will useing a HD tv help?? i have optimum online service wich seems to work well but they offer BOOST an even fast connections speeds would that make a differeence??
OK any help or idea's would be great
ThanX
I would be almost sure that the inherent PQ issue is with the bit rate /resolution of the product itself, not anything on your end. Does their hardware or brochure offer any info as to what their transmission rates are; max? Using an HD display would only make things look worse for low rate/res SD programming.
What if i were to record the games to an HD upconverting DVD recorder would the DVD's turn out to have better PQ????
Please leet me know if you think that might help. I do not have any ifo on there bit rate but i will try to find out.
thanX
Toshiba 50" DLP settings
Optoma HD70 review is up at Projectorcentral.com
