Image Revision Problems in Sony GWIIs | SatelliteGuys.US
Not open for further replies.
Sean Mota
19,039
1,739
New York City
If you own any of these two models:
KF-50XBR800/KF-60XBR800
and you are having ghosting problems that cannot be corrected with user menu revision, you may want to try the service menu and get rid of the ghosting. I own one of these beast and I was having thi issue and it was getting worse as the lamp kept burning hours. The only thing that solved it was to go to the service menu.
UMR a user at AVS has done wonderful works with these two sets and this is his tweak. You can find all the information on this thread. http://www.avsforum.com/avs-vb/showthread.php?p=6982718#post6982718
I've got the 50 inch model. If you mean the pinkish ghosting line, it's really pissing me off!:mad: I went into the service menu, but got scared and exited, I don't know what that stuff means!:o
Getting Frustrated... How do you make VCDs or DVDs quick and easily?
I tried ITVN and loved it
