iamanedgecutter wont work? | SatelliteGuys.US
SMG
24
i have an HR20, and cant seem to see the changes after i enter the code.
what am i missing?
What version of the software are you running. Is it a CE version? After you do the word search you need to press the Menu & Info buttons, at the same time, on the front of the unit not the controler, then go to Menu then setup and you will see the option menu show up.
CEs for 10/3
Incompatible video signal
