I thought only VIP seris can use DISH REMOTE? | SatelliteGuys.US
papalittle
1,375
Some old corn field, United States
DISH Remote Access
Overview
Description: DISH Remote Access gives you total control of your DVR anytime, anywhere, so you're sure to record the shows you want, when you want. Simply use your laptop, PC or iPhone to connect to the web and fully manage your DVR. Don't just set your recordings….see and manage your DVR as if you were at home.
Browse and search the program guide
Create timers
Delete timers (IP only)
Manage your DVR library
Manage recording conflicts (IP only)
Watch TV or DVR recordings with a connected Slingbox or ViP 922 (IP only)
Requirements
Supported Receivers
DISH DVR 512
DISH Player 522
DISH Player 625
ViP 612 DVR™
ViP 622 DVR™
ViP 722 DVR™
ViP 722k DVR™
ViP 922 SlingLoaded™ DVR
Compatible PC, Laptop and Mac Web Browsers
Firewall Issues
Satellite Usage Limitations
I am confused on this.
How would I make this work on my 625 then?
Make it work ? It already does... Did you try ?
On non-ViP receivers, it "programs" via the satellite feed. Notice how some features say "IP only" ? Those features require two-way communication, hence why they're unavailable on the 512, 525, and 625.
It will allow you to setup timers that are sent via the satellite signal. Keep in mind though receivers not connected to broadband will be limited to 5 event timers within a 30-minute time span.
I could be wrong.. But I thought it had to be hooked up by at least a phone line.. Since you can't hook up Internet to those models??
Reminder - Final lift off 10:00 AM
Heavy data use detected after connecting receiver to internet
