let's hope they don't blow it. buying the voom satellite gives you extra space. use this space wisely by adding more hd content and you might gain some subs back.
Scott Greczkowski said:They could uplink over 24 HD Channels in MPEG2 format which would give Dish a change to let DirecTV be the MPEG4 gunnea pig while Dish sat back and waited for the second generation MPEG2 chips to come out.
Thats what I would do.![]()
Scott Greczkowski said:FOX HD should be up for the SuperBowl (but only for the SuperBowl) and only for FOX O&O areas.
splino said:Scott, where I live I qualify for all Distant Networks and CBS HD (Not being able to get any of them over the air.). Would I qualify for the Super Bowl transmission?
Scott Greczkowski said:There are (RSNs broadcasting in HD) but none of them broadcast 24/7 it would be easier to setup 2 sports HD channels and insert the programming then have dedicated channels to them.
I wish I could make it happen, but truth is Charlie can't afford me.Airblair said:I totally agree with this. Scott, make this happen.
Scott Greczkowski said:I think it was a wise move by Dish as well, they thing that concerns me is they do not have plans for the satellite or transponders which they will be aquiring.
If I were Charlie, I would shuffle some stuff around off of 61.5 and 148 which is there now to other spots such as SuperDish locations. I would then uplink a bunch of new HD Channels in MPEG2 Format to both 61.5 and 148.
Scott Greczkowski said:There are but none of them broadcast 24/7 it would be easier to setup 2 sports HD channels and insert the programming then have dedicated channels to them.
Limited time offer
