I/O Digital Question | SatelliteGuys.US
joev
15
I plan on purchasing a HDTV set and want to know if I can feed non-HDTV ready TV's off of the one I/O digital box via splitter? Thank you.
Sean Mota said:
You can always use composite and s-video but I do not know if you are going to be able to see the HD channels downresized to 480i.
the io box will downrez it to 480i you can get the hd channels via composite just in sd
you can the only thing is that all tvs controlled by the same box will be on the same channel. also you need line of sight for the remote in less you have ir transmitters
Charter STINKS, what are my options!
Telstart 12 using a starchoice dish
