I need some info....help please! | SatelliteGuys.US
spotdog14
2
Hello. As the title may let you know, im in need of a little help. Let me start off by saying that the current setup in my house is 2 dual tuner box's. As with many house's our's was originally wired for regular cable.
So when the Dish network guy came out, this is what he did, the first dual tuner is in the living room, with the second line going to the kitchen. The second dual tuner is in the master bedroom, with the second line going to my bedroom.
Now, i just moved back from college, and cannot live without my MCE PC anymore! I just purchased a 311 off of ebay, i liked this one because of the S-Video output will give me superior quality when recording things on my MCEPC.
Ok, the way he wired my room was, he took the existing cable jack, put a female to female extender on it and ran the rest of the wire to the master bedroom to feed off of the dual tuner capabilities. (this is outside at the cable box of course).
So what im thinking i need to do is just remove the extender outside and plug the original cable into the sat distrobution box right? And then hookup the 311 in my room, to phone line, power, cable etc. And call dish network and activiate it....
The part i am fuzzy about is where to hook up the cable to outside....
Any help on this would be great.
Thanks!
Thanks!
You will need to add aditional capacity to your dish. Two receivers is all that you can currently run off the DPP Twin on your dish. A DPP44 switch should run about $200 call DISH at 800-333-3474.
thank you very much for the into! i didnt know that. If all that is going to have to be done, then i might just have the installer config my third sat box.
There's going to be a significant charge for that. The problem is that you're going from 4 to 5 total tuners, and that's ALWAYS an issue.
The True HD era has come to an end and the HD Lite era will continue!
ACT NOW NO! to 1280x1080i link below:
