I need help with Pansat 3500 and SD card | SatelliteGuys.US
Hambone
31
5
I thought I would mess around and try to edit my channels on the 3500 so I bought an SD card and reader. I downloaded G-Tools from the Pansat site and downloaded my receivers channels onto the SD card. My channels from the receiver were saved on the card with a BIN extension and G-Tools wants a GTD extension. How do I make the 3500 save the file as a GTD or what am I doing wrong? Thanks.
I was going to try that but I couldn't find a "." in the available letters and symbols. I'll look again and see if I missed it. Thanks.
oh crap I thought you meant you already had this on the computer...sorry
I dont know exactly how to do it that way.
I went ahead and downloaded Channel Master and it opened my channel list BIN file on the SD card. I was then able to save it as a GTD file and then I was able to use G-Tools to open it. I think I like Channel Master better anyway from the little that I've messed with them so far. Sure seems like G-Tools should work straight from the SD card since it's what Pansat offers on there web site. I'll have another go at it tonight and see if I missed I missed something simple. Thanks.
I was going to mention Channelmaster but didn't know if you had it.
I use CM and it works really well…well as I put it the other day "this thing kicks ass". I use it on my KUSat 2600, Coolsat 5000 and Pansat 6000
Whats BUD? Direct vs Dish or FTA????
Question on LNBF and Dish
