I need help with dvr 510 | SatelliteGuys.US
sierrasmoma
9
I need to know will the old lnbs work with a dp34 switch and the dvr 510 .I am having trouble getting signal can someone tell me how to hook it up with the dp34 switch .I need to run two dvr 510 off the dp34 switch
Dish Pro anything will work. But it's preferred to use a DP Twin. Wished I had a link to a PDF file that can give you a better and more accurate description in what's needed to do.
Hopefully someone will chime in with that info
Switch check failure
Uplinks Today
