i LOAD + | SatelliteGuys.US
i LOAD +
jahlight
102
I asked this in the DVR forum with no luck so I thought I would try here. E* people seem to be techies.
Has anyone seen the new product iLoad+? it is at iload dot com and supposedly you can use it to connect to Cable and/or satellite and it allows your iPod to be used as a DVR.
Sounds to good to be true.
just from looking at the site, i would say yes but i personally don't think it would work with anything other then Cable. never know tho.. buy one if it doesn't work send it back.. and just so u know its not a full DVR more like a DVR LIght w/ no pause or rewind type functions.
A second look seems like for sat you need to have it hooked up threw RCA/ coax from the Sat Box. that makes more sense now.
Quick install question new HD TV
superdish "check"
