I Just get the Twinhan USB StarBox is seems work very good on EPG, seems faster than | SatelliteGuys.US
ftadog
I Just get the Twinhan USB StarBox is seems work very good on EPG, seems faster than any PCI card and Receiver, I can get Indian Channel too.
Need advice on your configuration
Hi-
I am trying do the same set up. Can you tell me your config -I am buying Twinhan USB, have XP Professional and want to get Indian channel/s and BBC. Can you suggest also, which dish would be best to work this?
Can I use LNBs from dish or dtv?
Not Yet Available - PCI Express DVB-S Card
