I have decide to sign up for Directtv. switching from Dish. Help me do it right. | SatelliteGuys.US
lanarick66
3
cold michigan
I have not committed to anything yet. I have decided to sign up for Direct as I will save overall. I am a senior with limited means. My husband likes the sports. I am thinking of Choice or Xtra plans.
We have two tvs. I would like to have Direct on both, but it could be duplicate of tv 1. Can you run a cable or splitter to second tv like you could years ago. I see from other posts that I would have to sign up for 2 tvs and then return the genie. I would love any or all suggestions to keep my monthly bill down. I am going to sign up through Costco because of the $200 card.
Any suggestions or help before I become committed for another 2 years. Thanks!
:welcome to Satelliteguys lanarick66!
All outputs are live on Directv receivers/dvrs, so you can use the component output to feed a second tv if you like. If you are watching a channel that uses HDCP, it will disable the component output though. HBO and other premium channels use HDCP. The extra box, whether a client, receiver, or dvr, costs $6/month. If you get a Genie, you should keep that and return the client or other box. The monthly cost would be the same.
Can I decode the HDCP with a splitter, not to record, just to be able to mirror primary tv? Do non-premium not HBO, SHowtime programs use the HDCP also?
Welcome to the site !
The second recvr would only cost you $6 more per month.
You might want to inquire with the Costco D* rep about getting a Genie and a HR24 and see what they can do for you.
A genie & an HR34? I thought the HR34 was the Genie. exactly what equipment should I get? I would of course want the most recent receiver model.
The Genie is a HR34/44 debating on which ones they have currently ..
The HR24 is what I mentioned, thats a HD DVR ...
Can a new customer get the Genie with only one TV hooked up?
HR44 New issue, Anybody else?
