That's typically a ground loop. Something is not grounded properly.
Maybe your cable is too long. 100' a long distance for component cables. My guess is thats your downgrading signal. Component isn't digital remember.Hi Guys
I just connected my second HDTV via 100 ft long component cable with my 622. I am getting humming noise and faint white horizontal line going across the screen.
My primary HDTV is connected via HDMI. Any suggestion on problem..
You could have 250 feet of component on RG6 and not have any problems. More than 6 feet of HDMI and all bets are off since that is all the spec was written for. His problem is definitely ground loop and he will need to try to figure out which outlet has the problem.Maybe your cable is too long. 100' a long distance for component cables. My guess is thats your downgrading signal. Component isn't digital remember.
Limited time offer
