Hughes HTL-HD Guide Question | SatelliteGuys.US
gluck75
67
Manhattan
Quick Question
When I am going through the stations using channel up or channel down on my remote when I am NOT using the guide, it skips some stations. For example, it goes from channel 508 to channel 521 and skips everything in between. However, when I use the guide, all the stations are available. Why would this be?
Gluck75, that is because your using the "all" channels guide click the Guide button twice scroll down & chose custom. You will then only see the channels that you did not chose to have hidden.
Or, put a different way:
When you are surfing around (channel up/down) the channels are chosen from your Custom list, but your guide displays ALL. To get the guide in sink with your channel surfing, choose Custom instead of ALL.
To get all the channels while surfing, you neeed to go to the surf settings and choose to display the channels that are skipped.
(I think I just confused myself.)
Anyone with Voom and DTV
NRTC question
