http_Streams.txt | SatelliteGuys.US
http_Streams.txt
sanjap
253
4
houston, tx
Does anyone have a http_streams.txt file with working iptv channels? I have a file with about 103 channels but only 1 channel working. Does anybody have a better file?
I doubt it is my connection speed. I have 18Mbps download and 4Mbps upload cable internet service. Crackt, Can you Please PM me your working http_streams.txt file?
this is my latest i believe.
crackt out,.
Crackt,
Thanks for the file. Can you give me an estimate of the percentage of channels you can watch off the list? Are there any other settings other than just putting the file in DISK2 folder?
ill see if i have time to check some out tonight. i was watching almost all of those with an earlier firmware. it made the box sluggish so i havent played with iptv for a couple weeks. when 5006 came out i was gonna give it another go but it seems that maz will not play nice with this version. after spending 3 evenings trying to make a sat list with the last 2 patches only to end up with the box defaulting to the original sat list, im thinking its time to take a breather from my azbox before i go nuts. plus all these darn remotes are giving me nintendo thumbs. ill post my findings after i find them haha.
crackt out,.
crackt out,.
I have always followed this procedure (Thanks to Caseyman) to fix my corrupt file. I just use that method to up load my last working file.
crackt out,.
I was referring to the ip_channels.. not satlist
.......if you noticed, I quoted Crackt's post when I responded. It might not be of importantce to you, but Crackt who talked of Satlist being corrupt and having to replace them all the time might find it helpful.
Stereo audio from RCA L&R jacks?
Factory Setting VIA PC
