HTS Tracker System V instructions | SatelliteGuys.US
happyman
2
Can anyone tell me how to hook-up (i.e. wiring diagram) of a HTS Tracker System V?
the satellite is all ready set-up
Welcome to Satelliteguys :)
This may help:
Looking at back of reciever:
Far left plug in terminals: <1><2><3>
Left Center screw terminals: <4><5><6><7><8>
Servo Motor:
1 = Ground / Black
2 = Pulse / Clear
3 = +5v / Red
Actuator Motor: (thickest wires)
4 = Ground / Black
5 = +36v / Red
Motor Sensor (for actuator)
6 = +5v / Nothing connected
7 = Pulse / Brown
8 = Ground / Blue
Taken from Usenet.
If you hook up the wires wrong USUALLY you wont damage anything. Here are symptoms of stuff hooked up wrong
1) Dish moves east when told to move west= actuator (thick wires) hooked up backwards
2) can only view 1 polarity= polarotor servo motor wires not hooked up properly or bad servo
3) try to move dish and get a NP or No Pulse on the reciever display= actuator motor sensor wires not connnected properly
Good Luck :-D
noise on C-band
weird transponder situation question
