Hr34 issues | SatelliteGuys.US
Hr34 issues
drainsurgeon007
104
I have an hr34 that doesnt work properly it has been connected to 2 different tvs both have suffered multiple main board failures. The 34 will spark when connected to and hdmi port on tv..... Does anyone have any ideas to help remedy this issue..........thanks
You have a serious electrical problem, probably nothing to do with the HR34. My guess is that you have a grounding problem, and it's causing current flow along the HDMI cable. Suggest you get an electrician in to look at this, it's a serious safety issue.
Multiple hd receivers
Genie client (c31?) won't power back up
