HR34 / HR44 CE Release 11/29 | SatelliteGuys.US
jcrandall
Proud Staff Member
Staff member
HERE TO HELP YOU!
Apr 3, 2005
11,054
456
Central Michigan
Systems in this CE
HR34-700 Genie
HR44-200/500/700 Genie
Window of opportunity to download:
Friday November 29, 2013 11:00PM - 2:30AM ET
Saturday November 30, 2013 11:00PM - 2:30AM ET
Risk Level for this Download:
Moderate Risk
New features
None
Improved/Updated
Under the Hood
Stability
Fixed: No Audio/Video issue
Notes
PLEASE MAKE SURE TO REPORT ALL ISSUES WITH THIS RELEASE
You may lose your guide cache
Please allow up to 24 hrs to restore your full 14 day guide
Your STB may restart during idle time within the first 24-48 hours of CE download
Please do not report sluggishness or missing search results within the first 12 hours
Please send logs along with all reports, including MRV issues. When possible please use REPORT ALL.
The code doesn't work for me on the HR44. I have two HR24s and have no problem entering the code on those. I've had the 44 for a couple of months and tried the code every weekend, but haven't had any luck getting it to download the software. Is there something different or a trick for getting the code to work with the 44?
lost you tube and Pandora on the hr44 and the hr24 after downloading the ce.
HR 44 code
If you use the other remote the type you have with the HR24 the codes will work. I had the same problem i have an NFL remote that i like and is lit, but the RF will not work on the HR 44. So i have using NFL remote and found out it works.;):confused:
Post Turkey Day CE's
HR34 / HR44 CE Release 12/6
