HR34 Guide problem (not an HD Question) | SatelliteGuys.US
Lanarian
335
Pocatello Idaho
My HR34 guide is showing "All Channels" when set to "Channels I get", its not showing SD Duplicates, but is showing channels to which I'm not subscribed..
Anybody else run into this? If so, any recommended Fixes?
Info:
HR34 on the latest software release (Not CE).
H24
Whole Home
Internet connected
All systems seem to work fine, just the annoying guide thing...
Thanks in advance!!
The channels I get function has never worked properly. Your best solution is to set up a custom list.
Issue resolved.
I had misread the problem. It's not the guide, it's an issue with Wrong Dish Installed (See my other post if interested).
Basically, it's showing a lot of greyed out channels, which are actually channels included in my package, but unavailable due to the Dish can't pull signal from the appropriate satellite.
Volume control for Surround Sound
Question Regarding SWM
