HR34 CE Release 9/14 | SatelliteGuys.US
jcrandall
Proud Staff Member
Staff member
HERE TO HELP YOU!
Apr 3, 2005
11,054
456
Central Michigan
Systems in this CE
HR34-700
Window of opportunity to download:
Friday September 14, 2012 11:00PM - 2:30AM ET
Saturday September 15, 2012 11:00PM - 2:30AM ET
Risk Level for this Download:
Customer Candidate
New features
None
Improved/Updated
Under the hood
Notes
You may lose your guide cache
Please allow up to 24 hrs to restore your full 14 day guide
Your STB may restart during idle time within the first 24-48 hours of CE download
Please do not report sluggishness or missing search results within the first 12 hours
Please send logs along with all reports, including MRV issues. When possible please use REPORT ALL.
Customer Candidate
Previous Release Info:
{CE:05:01} 0x05B9
Support for hard drives that are bigger than you can buy
CE Feature: Report All
Rover finds and records shows you may like and uses drive space that wasn't available to you anyway
{CE:05:02} 0x05BB
Drop from Rover
Still unable to schedule future recordings from my H25 receiver to my HR 34. Says program is already scheduled to record for every show I try. If its live or a series recording it works fine! grrr
I still have my Pandora and You Tube and have it always after CE Download :)
I have the new CE Software. It appears the new Rover feature is available and does show the the new TV Shows Icon under Search and Browse, if I select the feature I get a Dialog box that says, "TV Shows is currently updating. Please check back in 1 hour". Its been like that since yesterday (The first day I noticed the new feature was available).
John
I noticed this is the last day or two (have not been watching much tv this past week) - but my HR34 seems to go into standby after 1 hour. The Power Saving feature was on but it look like that should be 4 hours, not 1, before going into standby. Anyway, I switched it off to see if it helps. Maybe the new one will resolve that. I would be watching a show and then after an hour of not touching anything, the screen goes blank and I get the Directv logo.
CE's for the Weekend of 9.14
HR34 CE Release 9/21
