HR2x / R22 CE Release for the Weekend of 8.20 | SatelliteGuys.US
dfergie
Proud Staff Member
Staff member
HERE TO HELP YOU!
Systems in this CE
HR20-100 • HR20-700
HR21-100 • HR21-200 • HR21-700
HR22-100 • R22-100 • R22-200
HR21Pro • HR23-700
Window of opportunity to download:
Friday, August 20, 2010 11:00PM - 2:30AM ET
Saturday, August 21, 2010 11:00PM - 2:30AM ET
Risk Level for this Download:
High Risk
New features
  • Support for external hard drives with Advanced Format (4K sectors) - DIRECTV has not yet qualified compatible Advanced Format drives.
  • Improved Smart Search results display
Improved/Updated
  • Under the hood
Notes
  • This CE may remove your guide cache if you did not download a previous CE. Please allow up to 24 hrs to restore your full 14 day guide.
  • You will lose your guide cache when reverting from CE to national.
  • Please do not report sluggish issues or missing search results within the first 12 hours after download.
Live buffer problems on HR21-700 with 0x412
HR21-700, CE Release 0x412
For the last two days, I have had problems rewinding the live buffer while watching The Weather Channel HD (362). If I press the record button, I can then access the recording through My Playlist and rewind will work properly. When I return to the live buffer, the rewind problem is still there. Pressing rewind causes the screen to freeze for about 2 seconds and then jumps forward to the live stream. Reset using the menu reset function corrects the problem.
Report Key: 20100825-353A
Software D/L
H24-700 CE Release 8/27
