HR23 will not connect to internet | SatelliteGuys.US
Sparkman
1,308
36
Charlotte,NC
Got D*in August, hooked up my 2 HR-23's to my cable internet with the powerline connection. 1st time I hooked it up, it worked fine. Now I cannot get internet. I am getting error 22. I have matched up default gateway, DNS, IP, but I keep getting this error. I have hooked this up to my laptop and it works fine. Any ideas?
If it worked before and now it doesn't...
Have you changed anything? If no, try rebooting the router (power cycle). Power cycle, reset the HR23s.
If you have not changed anything, and it worked before... it should work now. Just cycle everything.
could be a bad modem in the reciever, you say you had (2) recievers hooked up? if so and they both dont work it is probably not the boxes, if it is just one then probably a bad box.
Whats connected to what, in which order?
And when you say you've matched up the IP address, what did you mean?
install question
Multiple HR23 using IR
