HR23 Pink Screen | SatelliteGuys.US
HR23 Pink Screen
Mark0525
113
Ohio
The last week or so when I turn my TV and receiver on the display is pink and there is no sound. I do a reset and it's fine. Not a big deal just takes a while to reset. Happens every other day or so. Any ideas?
happens every other day or so?? maybe you should call D* and have the dvr replaced.
If you want to diagnosis it, I would look for and reset any connections, Component or HDMI .... If that doesn't fix it, I would suggest calling D* about a new recvr.
It doesn't do this initially on any other inputs does it ?
What happens if you move the recvr to another TV, does it still go pink ?
I haven't tried moving it or anything like that yet. It's only about a month or so old. I will try running it without it being hooked up to the network but then I wont have the MRV to use. I hate to have them send me a replacement because I may not get another HR23. But then maybe that's a good thing.
If you have more than one hdmi cable, try switching the hdmi cable or like jimbo mentioned switch to component cables and see if it does it again.
Billing Problems.............
Hdmi Wall Jack
