HR22-100 Guide is displaying "To be announced" | SatelliteGuys.US
skybyrd
36
Hello,
i got HR22-100 Receiver and i installed a Slimline 5 with one coax going to the receiver through a b band converter. now heres the the thing everything is working but:
1) it need to be plugged through tuner#2 or else no image will appear and will always say searching for satellite signal
2) i cant see anything on the guide it says on all the channel to be announced,
except for my local channels which i can see the guide
3) after 1 h i will have a popup saying contact directv theres a problem with the guide
4) after 7 hours grey screen and it says aquirinfg datat forever.
5) i have very good signal on all satellites including 119
6) i just got it and the guide was working for maybe an hour
what is happening
Hello,
what is happening
Did they hook up BOTH feeds to the back of the recvr, Sat input 1 and 2 ?
IIRC there's a place in the satellite setup to specify that you have only one tuner connected to the dish, did you set that correctly?
im only using 1 tuner, where should i go to specify only 1 tuner or 2 tuners to be used
I've never had to do this on a Hr20- or r16 to use 1 tuner.
I connect 1 wire, reset the receiver and its fine.
When I added the other wire back for the 2nd tuner, I just reset the receiver again and it was fine.
No of this effected my guide data in the process.
what are the proper way to do a reset
i did it and it worked for about an hour than all of sudden... it came back to what it was to be announced, 5% of the channel will display the info and the rest to be announced.
im pulling my hair whats hapening. it cant be a bad box
Its a Bad Box. Or you are having a signal issue. Call Directv.
Well, since the OP never said if he did or didn't I again recommend to check the satellite dish setup, in there is a field for tuners, make sure that it says single, if it says dual highlite it and change it to single.
I still do NOT think this is correct - if you are using only 1 tuner, you must use input 1 for everything to work properly.
If you can't get it to work otherwise, I say bad box, or maybe even a bad BBC is possible...
well thats what i found odd is that only tuner #2 will display an image or else if in tuner#1 it will say looking for signal....
I will try to test the BBC, if not i well i will have to use it with no guide.
but again its odd that all my local channels displays the guide properly.
Ok, so i was able to bring another feed from my SL5 to the 2nd bbc , now when i did the reset it says searching satellites on tuner 2 error 771...
by accident i hit arrow down twice and a message which i forgot appeared i have hit okay and i was able to watch TV, now i get good signal on tuner 1 but tuner 2 i see 0 on al TP. but starnage with one feed only tuner2 was working.
I would just go through the setup satellite again. you have 2 feeds to the box now, everything should work it's self out on the resetup.
If it doesn't then you know you have a bad box or something more and would need a service call unfortunately.
Ive noticed that since i have added the 2nd wire from the dish to the box, the whole guide is populated Yeah ! ! !
but now tuner #2 is displaying 0 on all TP's, what should i do next guys.
I recommend you reverify the antenna setup, hit "Menu" on the remote then select setup then satellite and then repeat satellite setup and verify that it has the correct dish/LNB setup and since you have two connections now that it shows two tuners.
i went in tuner setup and i selected dual tuners, on tuner1 signal is in the upper 90 for almost all except 103 and 99 and on tuner 2 its all 0. dish SL5 and multiswitch (im not using SWM)
Will this could be the dish problem ?
My Experiences hooking up new antenna
