HR21 - 0x021C CE Bug | SatelliteGuys.US
carlos31820
28
I'm having a recurring issue. For the past few days, all my scheduled shows have failed to record. When I check the History, all the shows show as canceled. Each show contains the following message:
"This episode was not recorded because the program was no longer available (13)."
I just reset the box using the menu. I'm hoping this will do the trick. Any ideas as to what is causing this?
Some are experiencing this issue with this CE, not everyone, just some. They are working on it, you'll want to try the new CE tonight to see if it gets better.
I reset the box using the menu and deleted/re-added two missed shows to the prioritizer. The shows recorded at midnight.
In any case, I'll download the new CE tonight. Thanks for the help.
HR21-ALL CE Release 3/21 & 3/22
R15-ALL CE Release 3/28 & 3/29
