HR20 thru HR23 CE Release 6/18 | SatelliteGuys.US
jcrandall
Proud Staff Member
Staff member
HERE TO HELP YOU!
Apr 3, 2005
11,054
456
Central Michigan
Systems in this CE
HR20-100 • HR20-700
HR21-100 • HR21-200 • HR21-700
HR22-100 • R22-100 • R22-200
HR21Pro • HR23-700
Window of opportunity to download:
Friday, June 18, 2010 11:00PM - 2:30AM ET
Saturday, June 19, 2010 11:00PM - 2:30AM ET
Risk Level for this Download: High Risk
New features
None for this release
Improved/Updated
Under the hood
Notes
This CE may remove your guide cache if you did not download a previous CE.
Please allow up to 24 hrs to restore your full 14 day guide.
If you do not see channel logos, please reenter IAMANEDGECUTTER and they will appear within 2 hours.
If you revert from CE back to National 0x3DE/0x3DF you will lose the guide cache and you are likely to lose some recordings.
Please do not report sluggish issues or missing search results within the first 12 hours after download.
"Under-the-hood" and "stability" improvements are expected with every release and are not noted here.
New features
CE:24:01 (0x03E5)
Posters everywhere!
DirecTV Cinema enhancements.
CE:24:02 (0x03E8)
HD PPV no longer requires the HD Package!
Output resolution is no longer limited to 480 when HD Package is not purchased
CE:24:03 (0x03EB)
Smart Search now gives you Top Matches!
Improved/Updated
CE:24:02 (0x03E8)
Black recordings
CE:24:04 (0x03EE)
Under the hood
CE:24:05 (0x03EF)
Can't delete issue
CE's for the Weekend of 6-18
Boston locals HD
